'97 TJ Sport - Driver Seat Tumble?
9363 25
I posted this question in another thread earlier but since it's off-topic I felt I should start a new thread. My main reason for doing this is because it seems a driver's seat that tumbles is pretty common, or maybe it was standard equipment on at least some TJs? I'd really like to find out more about this. Gee, 15 plus years with my TJ (I bought it new) and I've never been able to access the back seat from the driver's side. Anyway, what's the bottom line on the tumbling driver's seat? Was it an option, standard equipment, or something else? Any info would be welcome!
Original Post Below:
After all these years owning my '97 TJ I have to ask - Is the driver's seat supposed to tumble like the passenger seat does? I know I've tried it a few times but I couldn't figure it out. Duh.....
OK - I was inspired to go look at my driver's seat again. It will not tumble. No way. The seat back doesn't even fold forward past vertical. The mechanism to tumble is just not there.
1 - 20 of 26 Posts
This question has been asked A LOT and there are a number of threads. No one seems to know the real answer. It does not ever appear that it was standard with any model/year/package.
03 X passenger only here. Neighbor 03 Rubicon passenger only
Here's my 97 and it tumbles. The cable that goes through the seat often breaks so you have to push the little lever underneath
Knows a couple things...
Perhaps what I am calling tip (fold) and tumble is not what some of you guys are calling tip and tumble. My '97 TJ's passenger seat had a very dramatic release mechanism that completely released and moved the seat far forward into the passenger footwell. My driver's seat had a different mechanism and would not move anywhere close to that, it only moved about as far as the second to last photo above.
'97 TJ, 4L engine
Discussion Starter · #11 · (Edited)
:Thanx: Thanks for the info Jerry, and as far as my '97 goes it is exactly as you state: passenger-side only for tip & fold. Oh well, I was hoping I'd find out something new about that driver's seat.
PS - I saw the pics from 97Wrangler-242 above and he has different seats than mine. No pull strap on left side of seat to do the tip & fold (driver side). The passenger side has the little pull strap on the right side (makes sense - ya gotta be able to grab it to pull it). Also, no lever underneath.
I found one on CL for $45 for a pair. I do not need the passenger and he wont break the set but for $45 I think i will still get it. It is a pain to get to kids in and out of the back and to buckle into their carseats all from the passenger side.
Yipeee Kay Ayyy
'Fold and tumble' is the term given to the action of the rear seat.
'Slide and tilt' is what the front seats do.
And yes, both front seats on my '97 do this.
When I bought my TJ, both seats would slide, but neither seat would tilt forward.
On one side, the seat release cable had broke, so replaced it with one fom here.
Jeep Wrangler Seat Release Cable Repair 1997 up TJ
There are about 4 different cables, so you will need to pull your seat out to see which one you have. I actually bought the wrong one but was able to make it work.
On the other side, the metal release paddle under the seat was so stiff it couldn't move - with some lubrication and plenty of moving back and forth, it loosened up and now works like a charm.
'97 TJ, 4L engine
Discussion Starter · #18 · (Edited)
Just for FYI - The factory service manual isn't much help. It doesn't give you a good view of the mechanism of either seat and does not give a clue how to operate the seats. The owner's manual is almost as useless. It makes no mention of the driver's seat being able to operate the same as the passenger seat. A BIG however, it did remind me of the little lever on the back of the driver's seat that releases the catch so it can fold forward (the seat back only). I plumb forgot about that! :facepalm:
Thanks to all for the comments and info! Shook a few cobwebs loose in the old brainpod.
I took the fold and tumble seat mounts out of my 2001 TJ and installed the fixed ones from a 1997. I have not looked at them for more than a year but if they are complete and i still have everything i will list them for sale this weekend. One of you guys could convert your seat
'97 TJ, 4L engine
Discussion Starter · #20 ·
Get them quick
I'd jump on it! The ones on eBay are $215 plus about $25 shipping! If they were less costly I might get some. Oh well, other priorities.
1 - 20 of 26 Posts
