Hello all,
been investigating different options of getting a little more speed and to decrease the RPM's. I know the obvious answer is to put the 4.0 in it but I am trying to avoid the $1500.00 expense in buying a new motor and having it put in. Cruising down the highway at 60-65 mph I am at 2900-3100. Any suggestions would be much appreciated. Thanks all
Nick T.
What size tires do you have on right now?
33s which is a problem obviously. I had the same issues with stock size
Your going to to have less issues with stock tires. Your options are 1)go back to stock tires, 2)regear to a higher ratio, 3) motor swap, 4) forced induction. Everything else is a waste of money.
