1 - 20 of 25 Posts
I just bought a 98 wrangler. My ? is the rear door or whatever its called does not swing freely it feels like opening and closing the vault door on Fort Knox. Is there any adjustment i can make. Thanks :banghead:
Open the tailgate completely and drill a small hole (about 1/8") and fill that hole with pb blaster and work it back and forth. wipe away the rust and dirt that comes out and keep doing it. The issue has to do with dissimilar metals and causes rust buildup
I tried the hole-and PB blaster-strategy too and it did work for a while... at least it made thing better, but mine was too far gone I think. I ordered a used pair from Davy's Jeeps, which worked very well.
Where are you drilling the hole?
Is this into the tailgate part of the hinge on the side.
mine were like that too - I replaced them and was done with messing with them...
hope the 04's will be better.
The hole does not have to be very deep. Just break through the outside of the hinge and into the second layer don't drill to deep into the second layer though
Top hinge
Bottom hinge
Sorry for being sideways
Top hinge
Bottom hinge
Thanks man
Is there any play in the bolt holes on the stock hinges? (03 Rubicon) My tailgate acts like the hinges are 'sprung' or the tailgate is bent. (no sign of that at all). I have my spare tire mounted on a swinging holder that bolts onto the tailgate and passenger corner. But it takes 2 hands to close the gate securely. Tried PB blaster (didn't drill hole) spray white lithium (helped a little). Haven't tried to loosen up the bolts to see if there is any adjustment in the hinges. If there isn't, I'll have to order new hinges.
I believe the hinges are sealed so spraying PB doesn't really get into the hinge and is why people are drilling holes. Bad design all around. The best way is to get new hinges if you can swing it.
1 - 20 of 25 Posts
