can anyone please tell me where the recirc door on a 99 tj and do i have to remove to cowl to get to it or go into dash.
I think it's stuck open and I want to fix it closed
I know it is a bit different than my 2005 but pretty sure it is over on the far right side under the dash more or less behind the glove box. There should be a vacuum actuator to control it with a green vacuum line attached to it. The actuator moves an arm attached to the door. Often on any of the actuators that are not moving their doors the arm or either broken or has come off the door.
