I've searched and could not find help with this issue:
A/C Control runs low on fan speed setting 1, 2 and 3. When I put it on High it blows high like normal.
All other A/C Functions normal.
Simple fix? New A/C Controls Unit needed or something easier?
Good Afternoon Cordonovan,
It is a rather simple fix to replace the Blower Motor Resistor pack, the link below shows the resistor pack along with the pigtail that it connects to (sometimes the plug melts and you need to replace the entire pigtail too). https://smile.amazon.com/dp/B00BVB5GZ6/ref=cm_sw_r_cp_dp_T1_xQUtzb39RGEEW
My question to a more experienced Jeeper: This will be the 4th one I have installed over the last few years. I remember a thread somewhere mentioning that the Blower Motor itself is part of the the problem. Stating that as it ages it begins to draw more power (amps) than it is supposed to which overloads the resistor pack. What is the real solution here?
