98 TJ 4.0l
The compressor doesn't come on unless you tap on the clutch. The clutch is magnetized and when it does engage, the A/C blows cold. Could it be that's it's low on Freon? Bad clutch? rusty/corroded clutch from sitting and not being used for more than a year?
If you jump 12 plus volts to wire on ac compressor clutch magnet and it does not click locked you will know if it is or is not the compressor clutch ( that is if and only if the compressor has an adequate ground)
