A Jeep Named Sarah - '12 JKU
3272 Views 23 Replies 4 Participants Last post by  Martin L
This is going to be a long, slow process, but we're excited.
My bride and I recently bought a used 2012 JKU, the first Jeep for either of us. She has wanted one since she was a kid, so I don't know who talked whom into getting it. My wife loves the Terminator flicks, and is enamored by the look of Sarah Connor in her Jeep at the end of the first movie. I suggested we name our Jeep Sarah. I guess that's the beginning of our "build".
Sarah had only 14,100 miles when we picked her up and she gave us our first surprise as soon as we got her home - we thought she was black, but she's actually Black Forest Green.
We're not yet sure what we want to do - dunes, trails, rocks, mud, but Sarah's not going to be a mall-crawler. The first "mod" was an antenna bracket in order to mount a lighted whip/flag to be legal in the sand dunes called Glamis. The whip rises to eight feet from grade and has green LED's up the length of it. Glamis was our first ride off-road. What a blast. The following weekend we went up the Santa Ana mountains to Santiago Peak. We were by ourselves, unfamiliar with the trails, and don't know squat about wheeling, so we took it pretty easy.
We're signing up for an up-coming Jeep Jamboree at Big Bear, so next we added a CB and antenna to the mount we installed for the whip.
The previous owner had removed the side rails, so next we installed a pair of Smittybilt rock rails to go with a Smittybilt XRC M.O.D. front bumper with full extensions and bull-bar.
I returned to the sand rail shop where I bought the whip to get a quick-disconnect for it only to find they were clearing out some Vision-X 5" HID's at 70% off, so we added two of those to the bull-bar, but haven't wired them in yet.
Today we ripped off the cheap top (with ripped zippers) and installed a Black Twill Supertop-NX by Bestop. It's absolutely beautiful.
I'm building my own version of an S-POD and hope to have that installed in the next couple of days. I've already put four switches in the left A-piller and wiring for four more in the right A-pillar (I know that sounds dumb, but more on that later).
I'll take pictures in the next few days and figure out how to post them.
I've been reading this forum every day for the past two months and have learned a lot, but not nearly enough. I thank you all.
Here are our plans, in no particular order:
Rear bumper / tire carrier / Jerry can rack / hitch
Fog lights (need to fab something for the Smitty bumper)
Winch
20" light bar
Rear floods
2.5" lift
35" tires a new wheels, but with a 3.21 gear that means...
4.10 or 4.56 gear, but as long as I'm in there that means...
Rear locker (probably Eaton e-locker)
Front locker (probably an Aussie)
Inverter
Raised rear deck
And who knows?
21 - 24 of 24 Posts
Today I finished building and installing the relay/fuse box for my version of an sPod. I could have done a neater job with the bracket, but I didn't have the material I wanted for it so I threw this together and will replace it later. It's solid, just not cosmetically appealing.
The box itself is water-tight as well as all the internal wiring (fuses to relays and to/from terminal strips), but obviously the terminal strips are not. I'm not worried about that as high up as they are and protected from below. Also, there is nowhere to trap moisture. The terminal strip on the fender side of the box is for landing the hot wires from up to ten device loads and the terminal strip on the engine side is from the eight switches in the cabin. I could have wired the trigger switches directly into the box and eliminated the terminal strip, but since two relays are 35amp and six are 20amp I wanted to easily be able to swap trigger wires around if I want to change which switches are assigned to which relays.
Now all I have to do when adding up to the next eight devices (such as a light bar, spot lights, rear lights, rock lights, etc.) is ground it to the nearest point on the chassis and run a single wire to the terminal strip and that's it !
The switches and all the other wiring is already done !
Would love some more details on the box. I need to dig into the thread more though! I considered right and left pillar mounts for my jk as well
I was second-guessing myself for awhile, but I'm more confident now with my decision on the pillar switches. Right will be air compressor, front locker, rear locker, inverter. I don't see needing to get to those instantly even though I can reach across with no problem or wake the wife. Left can be for lights - flood, spot, rock, rear. Not like I need to get to those in a hurry, either, but it seems like a good grouping. Of the three non-relay switched loads in my "Marty-pod" I've got one going to the CB without a separate cabin switch and two discrete switches under the steering column for whatever (right now one is for the lighted whip).
I'll dig up my notes on my pod and send them to you and/or start another thread. I was surprised to see how much interest was on the thread for a DIY fuse/relay box when I stumbled on it today. Too bad he didn't finish it. I think I spent about $150 on mine. Now I need to come up with the $10,000 to install all the stuff I want it to control. :)
Totally hear you on the money for mods thing. I think what's so appealing about the diy SPOD is the functionality for a fraction of the price. I understand why they are pricey but most of them are out of reach when your considering lifts wheels tires bumpers winches lights and lights and lights. Notes in a new thread would be great too, whichever works for you. Thanks!
Installed "GraBars".
Wow! Sturdy as can be.
There are seventeen zillion pictures of Jeeps with GraBars so
I won't even try showing a better one.
Instructions were great (and detailed), fit was perfect, and
end result was as advertised and bragged about by many
others.
This simple, pictureless "mod" might just be the most
functional one I've done so far. A deal at twice the price.
They look great and work even better.
21 - 24 of 24 Posts
