you're mistakenly assuming all TJ's can lock up their brakes to begin with :mooning:Find an empty piece of road. Jump on the brakes. If you lock your wheels, you don't have ABS.
This. It's that simple to lookThe ABS system resides on a small tray on the driver's side behind the front fenderwell, with brake lines leading to it from the master brake cylinder. If that tray is empty, no ABS. The tray I am describing is big enough to look like a battery tray but it's really meant to hold the ABS system.
Thanks Neil, simple is good lol.This. It's that simple to look
