On my 2010 2 door after sitting, usually on first crank up in the morning, the abs and traction control light will come on and bring the jeep to a stop. After pushing the gas and letting off the lights go off the jeep drives normal until it sits for a while. Then it does it again.
Retired Moderator
:welcome: to the Forum..:wavey:
2016 JKU 75th Edition, 2" Mopar lift 1" spacer lift, Ultimate Dana 44 front, Front and rear locker,
It is probably your wheel speed sensor. If you have a code reader it will tell you which wheel it is. You can also stop by a parts store and some will have code readers you can barrow. I had to replace both my rear ones. I bought the part on amazon and watched a youtube video for install.
Wheel Speed sensor issue. I had this too and had replaced under warranty.
Thanks for the response. You guys are right. I have a flash cal, and forgot it will read the abs code. Left rear wheel sensor.
