Krew Member
So, i was having a little problem accelerating, and my cat was rattling so i figured the honeycomb was getting stuck in the exhaust, so i cut the cat out today, got the rattling honeycomb out, and reinstalled everything..only issue i am having now, is after installation and test drove, more power than before and no problem accelerating, sorta. Once i reach about 2,500 rpms, the jeep jolts some, then continues on accelerating. Any ideas?
did you reset the computer by disconecting the bat terminals after doing that if not you should clear it. also the A/F may be a bit off from removing the guts causing the jolt.
Krew Member
Did not reset the cpu, was no light and no sensors changed..a/f might be off due to the o2 sensor not seeing the out put like it should be, you are correct, didnt think of it
