Hey guys.....I figured there was someone that could answer this a lot faster than I can figure it out.
Here goes....
I have the Alpine sub (Nav head unit) but want more "bump." Yes, I already put stuffing in all the speaker enclosures. I was hoping there is a "quick-connect" harness that i could add to my sub that will allow me to have another subwoofer box that I can take out quickly (ie...quick connect)
Can I do this and what should I buy to make it happen? I do not want to have to connect to head unit. I want a plug-n-play set up.
Thanks Guys.....
Brian
You can always go with a powered sub. I put a powered MTX 10" in my 2dr and its not much bigger than the stock sub the wife has in her 4dr. As far as hook ups it came with line inputs you could tap into stock speakers and use disconnects in the wiring to remove it.
I have an 8" and 10" flat subs, with amp, one under back driver side seat, one under front passenger seat. Plenty of bass. Not much room taken up. Also have upgraded speakers in bar, up front, and tweeters.
