Adding Coil Spring Spacer - Use Spring Compressor?
1644 1
I have a 4" RC spring lift on my TJ. I need to add 3/4" coil spacers to level the front. Can I get away with not disconnecting stuff if I use a spring compressor?
If not, will I need to disconnect the brake line brackets to lower the axle enough to get the spacer on?
