2018 JL Sport
A buddy of mine gifted a rubicon lift for my 18 JL Sport.
I know some kits have specific springs for each side and was trying to figure out if that is correct for the stock Rubicon lift. They are different part numbers but can't find which side they are specific for.
Thanks.
Front
Material property Sunglasses Cable Eyewear Wire
Rear
Light Automotive tire Material property Gas Cable
Retired Moderator
^^^ You are asking your question in the wrong Sub-Forum. The above is a Link to the correct Forum..FYI
Springs are not specific to model but by options. Check the spring numbers. Your Sport could have the same springs or very close to the same spring rate. The shocks are different and they will be good for you.
Bottom line, swapping 4dr springs into a 4dr Sport usually gains very little to nothing. The people that do the spring swap are those that put 4dr springs on a 2dr.
