1 - 13 of 13 Posts
Just curious if the 2.5l can handle the beach? Love the Outer Banks area but lots of loose sand. Can the 2.5 do it or do I need the 4.0 Thanks
Just got back from OBX. My Son has a 2.5/MT and he did just fine. Key IS ....airing down is a MUST. 4H - Keep momentum and you'll be fine.
And ... if you do get stuck stop spinning the tires immediately. That will just dig you in further. And turn off traction control if you have it.
I made it out on the outer banks with my old 2.4l I4 TJ back on 05/06. I aired down some times and others, I didn't. Depends on the sand.
As mentioned - key is to keep your momentum.
Each beach sand is different. If you run a wider tire, you may not need to air down. However, as mentioned if you start spinning, stop before digging 4 holes. Then air down. If you are worried about HP with the 2.4, low range is your friend.
make sure you bring enough beers for all of the ladies who come over in their bikinis to tell you how awesome your Jeep is (and flaunt their stuff). that should be your only concern...that you have enough beers for everyone
Just got back from the OBX. You should be fine, just air down and don't stop on the entry/exit ramps. That is a fairly common place to get stuck.
Oh, and don't drive on the dunes!!!! I see it happen way too often
Airing down is probably the best advice. My 2003 Subaru outback was a beast at OBX but I could still do it with the tires at standard psi. My friend brought a Jeep and didn't air down. He was making it through but the engine was getting pretty hot until he aired down. Lastly, don't drive really close to the water. There are these things called gravel pits that'll open up if something heavy goes over them. Ask the locals, they can explain it better.
I've seen a few Jeeps stuck before but as long as you're smart, you'll be fine. Enjoy the trip when you go!
Am I the only one who clicked on this link to find out if the OP did a 2.5 liter conversion on his JK? Crate motor perhaps?
Seriously, like other said - tire pressure, momentum and being smart go a long way. I recently saw an F150 buried to the bumpers on another beach.
1 - 13 of 13 Posts
