Hi I need some opinions, 2015 JKU 15K, driver side, power window stopped working completely, all other windows operate, luckily its in the up position, does anyone have any thoughts of what the problem may be Thanks
Check the driver door quick release wiring harness. If that doesn't fix anything, you could have a bad window switch. You're covered under warranty, so you might want to bring it in to your dealer.
Dave ,thanks for the response, checked the switch buttons, just thought it might be something simple, will def take in to dealer, thanks
