Also posted over at the AEV forum.
The instructions have you zip tie the front brake lines to the shocks. On my first wheeling trip, the driver side zip tie broke. I already removed the old brake line retainers per the instructions.
Any suggestions on a better retaining solution? Or am I the only that has had this problem?
Otherwise, lift is awesome. Love its performance on and off road. And will continue to highly recommend it. Just need to figure out the best solution for the brake lines.
Hmm, I've been running the same setup no problem. I'd recommend getting heavy duty zip ties, and dropping the axle and turning the wheels all the way to make sure you've got enough slack on both sides. Could be that your brake lines pulled the zip tie off from being too tight on one side.
