1 - 15 of 15 Posts
hey there fellow jk owners i got a question for you, yesterday i notice a noise while going over some bumbs. under the front driverside wheel area, worried me so when i got home i notice my coil was bending (photo below)
and then i noticed that the suspension spacer i just installed not even 2 months ago looks like it it failing appart(by either crumbling or spiting(photo below)) any ways im pissed if because i cant drive it till i get a new one... will aev send me a new one in replace of that or is there a place i can order one so i can get it opperation asap? also will i need a new coil becasue of this?
2nd pic is what is suppose to look like
My TF leveling kit did this on one side. The plastic spacer collapsed in an area and my spring didn't sit straight. It also made a weird noise whenever I turned and hit a bump. As long as it doesnt stay like that for too long i would assume the spring would be able to be used again. As for AEV sending you a new part, i'm not sure. I never even tried to get a new part for mine, I realized spacers were not the way I wanted to go, especially now that i've been wheeling more frequently so I just changed to a coil lift. Good luck! :thumb:
Contact AEV and provide them with the pics.
I don't know is he writing about just a spacer or leveling kit.
I have 2 inch AEV leveling kit installed. So far have only 1,000 ml on it and no issues.
I believe you and the OP are talking about the same lift. The AEV 2" lift uses spacers.
Yes. Some call it leveling kit and some spacer kit. Bottom line - same chit.
I wonder who did install for him ?
Maybe something went wrong during the install ?
Perhaps he will provide more details. Maybe the AEV spacer and factory isolator weren't mated just right or maybe its a bad spacer?
I AM THERE4 I JEEP
I had a similar issue when I installed only a 3/4 spacer with the stock springs a few years ago. They bowed because I was also still using the stock sway links and it cause the springs to bow out like that.
I looked at his pics again and the sway bar links look longer than the stock front ones.
It seems he only has this issue on the driver's side.
I AM THERE4 I JEEP
Yea I saw that too then edited my post a few back.
1 - 15 of 15 Posts
