1 - 13 of 13 Posts
I am interested to see if anyone running full set of skid plates (rock hard) is also running the AEV differential skid plate, and if they had to do modification ?
I checked with AEV, they said they haven't done any testing and are not sure.
I don't want to run the RC or Rancho option where part of the load goes on the bolts. AEV distributes the load on the housing.
Not running it but can't see where you would have any issues. Should be plenty of clearance - not even sure where there might be an issue with the axle slider and skids. Just my $.02 and a bump for anyone with specifics. Good luck.
I have a Rubicon and I am just running factory skids plus the AEV front skid and the the AEV rear differential slider. I don't see where there could be any interfernce with aftermarket skids but I don't know for sure. I love extra protection of the rear slider but I got a great deal on it. I paid $60 for a used one.
:iamhappy:
I'm not running those brands but I do have the RC fuel skid and RC rear axle skid which is very similar to the aev skid. I did trim the front part down (narrower) a little because I figured it might hit at full articulation if a side force was added. Easy to do with a sawzall and smooth the edges with a grinder.
not a good pic but it might help. It's actually a straight cut but thicker on the end so it looks wavy.
I've got the AEV rear diff skid and highly recommend it. That actually means something as I generally can stand the prices of the AEV stuff. Give me a minute and I'll post some pics, but I also have the Rancho one for the front and it totally rocks (or slides over them well).
Here are a couple I took.
At install:
The Rancho one really does a good job:
I couldn't find any others of the AEV one getting hit, but this is a bit of one:
Discussion Starter #10
Thanks all for posting the pictures....which gas tank skid plates do you have with the AEV diff skid plates
I have the rough country fuel tank skid. and the rugged ridge evap skid. no complaints on either one.
1 - 13 of 13 Posts
