Just arrived can't wait to have some time to get this in!!
Everyone's numbers are always optimistic. I think they have dyno stats on their siteTheir claim of 16HP and 24 ft. lbs torque increase seems a little optimistic. Do you know of any links to dynos on that?
Even with the dry filter Id still run a boot. Companies started making dry filters because of over oiling issues. Some have it in their minds more the better, but in Mass Air Flow systems like Ford and Chevy use, the MAF sensor is often right behind the filter. Over oiling can cause oil to be drawn through the filter and get onto the sensor making it read improperly. Most of the time, the sensor would go so far out of range the ECU would go into the cold loop start cycle/ run rich but there has been cases the sensor was reading enough and caused lean conditions leading to preignition/detonation.AFE make dry and oiled air filters. Does that intake use only their dry filter?
Very interesting. Thanks for posting that. I have a dry AFE in one of my cars that has MAF sensors. It rarely sees dusty conditions and thus has been a good filter for that car.Even with the dry filter Id still run a boot. Companies started making dry filters because of over oiling issues. Some have it in their minds more the better, but in Mass Air Flow systems like Ford and Chevy use, the MAF sensor is often right behind the filter. Over oiling can cause oil to be drawn through the filter and get onto the sensor making it read improperly. Most of the time, the sensor would go so far out of range the ECU would go into the cold loop start cycle/ run rich but there has been cases the sensor was reading enough and caused lean conditions leading to preignition/detonation.
Lucky for use Mopar drivers, Chrysler still likes the speed density systems so there in no MAF sensor to get dirty in over oiling cases :thumb:
That's it? That's all we get? How does it run? How does it feel? C'mon man, give us some details! :bop:AFE Power installed
Well, I took it around the block and it sounds amazing! I really don't have more than that at this point, but once I do I'll post some results.That's it? That's all we get? How does it run? How does it feel? C'mon man, give us some details! :bop:
Any update on your impressions?Well, I took it around the block and it sounds amazing! I really don't have more than that at this point, but once I do I'll post some results.
