1 - 11 of 11 Posts
Good info; thanks.
I don't know that I would blame the aftermarket wheels or the studs in this case. It looks like he didn't remove the retaining clips from the studs when he changed his stock wheels to aftermarket (which don't have the recess for them). This is what likely caused the failure as the wheels were not able to seat correctly at all.
That was the point of the post....
BTW, after reading this, I went to Discount Tire ---- time for a rotation anyway ---- and removed the clips. My ProComp wheels didn't have the recesses in them.
Now I know why I had to torque them down so often. Glad that nothing bad happened. They've been on almost 13,000 miles.
Discount Tire said they usually check....
Great info. What strikes me is How many things can go wrong and then multiply those odds by the number of Folks "modding" even those of us that know what we are doing and might miss some small detail that makes all the difference.
Now imagine those who don't know what they are doing.....
Wear your seat belts and stay aware Folks :)
I thought this was common knowledge, goes to show you can't expect everyone to know everything even if it is something you thought was common since.
I remember this from having my TJ, when I swapped the wheels out the guy was checking everything and telling me the horror stories of bad fitting wheels, caliper issues, brake issues, wheel weights catching on stuff, retainer clips, busted studs, warped wheels, etc. I learned a lot just hanging with him for two hours while he leisurely mounted and balanced my new set.
1 - 11 of 11 Posts
