I have the inner panel off, now looking at the black plastic covering the inner panel, how does that come out, it looks like the window motor and all of it is part of it
Aren't there screws around the edges?
If I remember correctly the door latch is also attached to it so you also have to remove those screws from the edge of the door.
Pull the top out some and look down you will see a channel in the middle of the door that has a piece that the window bracket slides in it's a silver color. There are 2 screws in it one near the top and 1 at the bottom remove the screws and slide the inter panel to the front you also see to skin colored tabs locking that panel on push them in and the panel will be off. It's really a pain but after you do it a few times gets easier.
