I just intalled an Air Raid brand cold air filter then the same brand throttle spacer. after intalling the spacer the engine now idle srather fast 1900 -2200 RPM. what do i need to check or do?
Are you running a 2.5 or 4.0? The 4.0's require a throttle cable spacer also that lifts and aligns the cable back to a horizontal position. Maybe you have tension on your throttle lever on your throttle body?
