1 - 1 of 1 Posts
I recently noticed the Airbag Light burn On-Off-On-Off, then dim glow on startup with my annual safety inspection approaching. I swapped incandescent to LEDs some time ago, and recently had the dash out for the dreaded heater core/A/C Coil swap...
I went through all the airbag plugs and wiring with no resolution.
I just swapped the airbag dash LED back to incandescent and voila! The light is ops normal. Apparently the airbag text cycle does not see the LED bulb "good" (less current draw?) on the startup check.
I hope this saves someone some time and trouble.
1 - 1 of 1 Posts
