Mtrs pull to the right. If your alignment checks out than Its simply radial pull. When I took my mtrs off and replaced them with nittos the pull to the right stopped but now it pulls to the left hahaHad my jk aligned at Sullivan tire today. But it still pulls to the passenger side. Any suggestions? 35x12.5x17 mtr/k tirea on factory wheels
This will be an easy way to start troubleshootingDisconnect your steering stabilizer and try it. I had a bad one and it pulled badly.
My Nitto's run straight as an arrow :winner:.Mtrs pull to the right. If your alignment checks out than Its simply radial pull. When I took my mtrs off and replaced them with nittos the pull to the right stopped but now it pulls to the left haha
I had a similar problem with a set of Goodyear Wranglers on my truck many years ago. I replaced the tires (with a different brand) and the problem went away.Try swapping the front tires.
actually on the highway its essentially straight as an arrow but locally even on a leftward slope it will eventually find its way rightare you sure its not just tracking with the slope of the road? mine drives straight as an arrow until i get on the highway then it wants to go with the slope slightly. When i change lanes so the slope goes in the other direction its goes the other direction....I just assume its the 12.5" wide tires....Does this sound normal?
