As I mentioned in another post, I took a fairly hard hit to the front of my stock 2015 JKUR this weekend (found a "surprise" drop-off in some sand dunes that was short and steep - the front end/bumper hit the sand with a good thunk). Aside from now dealing with some new wind noise around the top of the A pillars (that is the topic of my other post), I decided to get the alignment checked and had an alignment performed. The results are attached below. I was told that everything looked fine, even through the camber is off. I am a bit concerned that I bent something (including the frame). The jeep seems to drive fine.
Do these alignment number suggest a problem or do they seem normal? Are there any other checks I should do to make sure everything is fine? Thanks for any thoughts.
Thanks. KJ - are you suggesting that I check the ball joints because the camber numbers are off or just because it would be worth to check after a thunk to the front end?
