Finally got my toe-out fixed! Got a toe-in of .20 degrees now, not sure what that translates into inches but I presume it's just fine.
Caster went to 3.5 degrees, so a pair of adjustable control arms are in order in the coming months.
Camber is at -0.5 degrees on the left, and -0.8 degrees on the right. This influences tire wear I believe?
Is yours a 2012?
I got a free alignment check coupon which inspired me to have mine checked at the dealers. The dealer fixed under warranty. I swear it made a positive difference in the bump steer.
left toe
.09 (ok)
Right toe
Before -.02
After .12
proper range .09-.12
Front Toe
Before 0.06
After 0.21
proper range .17 to .23
It is a 2010. We have pretty much the same stats: your .21 toe-in vs my .20 toe-in.
My before measurements were horrendous. Left toe -.12 and right toe .37!!
Now it sits at .10 toe at each tire.
I'd hate to see how out of wack my alignment is between the hillbilly lift kit, the obviously out of round tires, etc.etc.
