Can anyone look at this alignment report and let me know if it is ok. It seems to be riding nice. 2.5 inch Teraflex, 35 inch nitto, 17 inch rims. Running 29psi in all tires.
Caster is a touch low (IIRC -4.5 or so is stock) but not much you can do about it without front CAs; but if she's driving fine nothing to worry about.
There are others on here who can comment more intelligently than I about thrust angles , etc. but I don't see anything else that jumps out as a potential issue. You should he all set.
looks good. If you add the teraflex fixed lower control arms you will be spot on. Needed no? just a little better highway speed steering control.
