I just put on a 4" lift along with sye. I replaced all ball joints,tierod ends,front track bar. Time for an alignment. Should I keep the 27" tires on it for the alignment or put 33"s on then get alignment? I would prefer to put 33"s on after.
Are you aligning it yourself or taking it in?
I aligning yourself, tires don't matter. You'll use your disk rotors to clamp an angle to for your measurements. Then Use the diameter of your tires for the distance.
If taking it in, use the tires you will be driving on.
I've already done a rough tow in. I'm taking to a shop to check everything,thrust,tow, camber, ect. The shop is a good 45m away.I prefer to use old tires until everything is good.
Personally I would throw the new tires on especially if you have already checked your toe in. One 45 min drive won't put wear them out if things are a little off. Then the shop can also check the tire balance while they are at it.
