1 - 20 of 91 Posts
Like so many I was tired of the Stock Head unit in my Jeep, sound while not bad (factory Alpine upgrade) I knew could be better, Uconnect had to go, would like to add Android Auto for many reasons etc etc etc.
I was on the fence about getting a i207-WRA for the better part of 2yrs, $1k is a bit of money when there are many other accessories fighting for my pocket change.
Enter the w650, available for UNDER $400, without the needed installation parts.
I can totally see another "kit" getting put together like the 207-wra which is an ilx-207 with all the needed parts to install in a Wrangler.
Part #1, Wiring
I went with a PAC PR4-CH11 $80
It may look like a spaghetti disaster but follow the directions and follow the color codes and its not bad, Black to Black, Yellow to Yellow, Red to Red, Stripes to Stripes, Solids to Solids.
This keeps the Steering Wheel Controls and integrates with my factory Alpine Amp.
You do lose front to back fading as you do with just about all aftermarket headunits while still using a factory amp.
#1-B FM Antenna Adapter Metra 40 EU-10 $6
#1-C USB Adapter for Uconnect in center console $6
#1-D Microbypass to get full access while driving or not need to use EBrake $15
#2 Dash kit to screw it down, Metra 95-6511 $9
Being a Sirius Sub and living in Maine, lack of FM in some remote areas
#3 Sirius SXV300v1 $36
Total from Amazon was under $450 for everything.
Plugging it all in and enjoying the sweet sound, think Foreigner Jukebox Hero...
Priceless...
Its been long known that the issue with any Jeep Sound system in the entire Jeep line are Dodge/Chrysler/FCA crap Decks.
You can add all the Amps/Subs/Crossovers/DSPs you want but with the Stock Headunit you are still going to have issues.
This is not only louder, by far, but importantly sounds better at any volume.
Best I can explain is and old Cassette thats been played 5000 times to a CD.
I had heard the Restyle kits at a few Jeep events with the Factory Alpine System and talked with the Sales people there and all the Restyle is is a new Headunit, Amps Speakers and Subs are options that you can add on.
Yes you do get obd2 readouts, tire psi, error codes, doors open or closed, etc etc, I also have EVIC and a Bluethooth obd reader, do I need any of that in a radio?
Hearing just the difference in a non-amped Restyle system I knew I wanted one someday, but $2k+ for a i209 or $1k+ for a i207... no thanks.
So I was able to get it all wired last night while it was raining.
Had 2 minor issues that I can work out.
The microbypass did not seem to do anything but turn on, its supposed to switch on and off to simulate the Hand Brake, I'll return or buy a new one.
The USB in the center console didn't work for Android Auto.
It worked great when I test fit everything till I added the adapter and the center console.
I'll return the adapter and see if there is anything else I can find, there were a few reviews that pointed out there may be issues.
It charges but thats it which points to data pins not wired correctly.
A few dark pics as I was figuring everything out
Being a "Mechless" Media Headunit it is really small.
Here is a side view with a key for reference
Here is video of the turn on and response of the capacitive touch screen
Its a simple interface, no animations or fancy menus but its all very quick and easily laid out
https://bit.ly/2IBZA1I
I am going to play with the start up splash screen and see what I can do to personalize it a little.
The different menu screens I'm fine with, the icons, the button colors all work and no need to change for me.
tl;dr... great sound for little money
Easily expandable with 4v preouts front rear and subs
Front and Rear cam capable
Wired ACP/AA
Looks like you can get everything from Crutchfield for about $369. But they are out of stock at the moment. I really leaning to this radio. Seems to be the cheapest way to get a backup cam.
Do you have steering controls and how are they working with the PAC RP4-CH11 Wiring Interface?
Thanks for the input.
RETIRED MODERATOR
Welcome to the Forum.
Thanks, I ended up with 2015 Wrangler Sport (Freedom edition). Has some nice upgrades, but the radio wasn't one of them. Uconnect just does not play well with iPhones. After the Radio and backup cam, I have so much I want to upgrade.
Full Steering Controls and you can actually reprogram them all to do exactly what you want, thats what the PAC RP4 was actually designed to do.
I did get in a new microbypass and tested it with a multimeter first and looks like this one actually works, hopefully it'll also fix my android auto issue.
Sweet, I'm going to pull the trigger. Thank you!
Another quick question, if you don't mind. I have seen other people do Radio install on youtube where they have to modify the dash on the jeep. basically cutting about a 1/2 inch on the top to make the radio fit.
Did you have to modify the dash at all for the install?
Discussion Starter #8
Yep you'll see some just cut the cross bar at the top totally out, you really don't want to do that.
There are two sides to the top cross bar, think like a piece of Angle Iron you might find at a hardware store.
The front vertical part of that cross bar will need to be trimmed to fit a Standard Double Din, its pretty soft plastic I used a Pocket knife and just took my time, other than that no other permanent mods.
Its maybe 1/4 of an inch, you don't see it once the dash is back together.
I left the rear metal frame in that the top screw from the top Dash pocket goes into, for the 67 Designs users out there.
Since this headunit is so shallow it doesn't even come close to the rear bracket.
Thank you again. I have it on back order. I did get the microbypass today, and I order the backup cam from Quadratec. I'll try to shoot some video for Youtube when it gets all in and post it here.
Thanks again.
Discussion Starter #10
My 1st microbypass had an audible click, which I thought was a good sign but it didn't pulse any of the outputs at all, which it needs to to access the full menus.
My 2nd one now is completely silent and works as it should.
Wire the Black to Black, Blue\White to Blue\White, and Yellow\Blue from micro to headunit only not to the wire harness to the Jeep.
Yellow\Blue should start at 12v at turn on then ground, pulse a 12v and back to ground to simulate turning the ebrake on\off\on.
Take your time don't get flustered you'll enjoy the outcome I'm sure of it.
If you don't have the factory Alpine Amp there is a great little addon you can throw on the back of the w650, the KTA-450 and you get real 50watts to 4 full channels.
All still inside of the dash, no amps under a seat or back with a sub box.
Discussion Starter #12
Exactly what options can you not access without the microbypass?
Its easier to say what you CAN do WITHOUT the bypass, change the Audio Source and Stations, Volume and simple sound settings EQ Presets and Bass and Treble, its same with all the Alpine Touch screen headunits.
To configure a Phone for ACP/AA, to set the clock, to do any of the advanced sound settings set crossovers, time correction, Media Xpander (which I highly recommend)... all things you really shouldn't do while driving which is why they lock them out you'll need to hookup to your EBrake or install a bypass.
All touchsreen headunits are going to have things locked out, its nothing new and its only going to get tighter and tighter.
Sad part is it doesn't help with bad drivers, just yesterday I had someone just about turn right into me, zero turn signal, zero warning just lane hopped like it was nothing, we were less than a foot away from touching.
Thank you to my dashcam if anything did happen I'd have it all on video.
Placed my order, along with a PWE-S8. I haven't done an installation in close to 15 years, so this could get interesting... :pullinghair:
Mine is on the way! Should have it tomorrow. I got bored and installed the backup cam. So all I have left is the radio install. I'll update here as soon as I get it installed.
Discussion Starter #15
I know right where you're at, I started my audio addiction in '96
Its actually gotten much easier and you don't have to rely on Crutchfield like days past
I still love em for all their Master Sheets and info but everything is plug an play or just match up the colors and go
I hope to keep this all simple and mostly stock with the factory Alpine amp but who knows in a year or two
Crutchfield was the greatest thing since sliced bread, back in the day. I may be dating myself, but my first radio involved cutting the factory harness off and hard wiring it to the radio...
All installed. Here a pic. The video will take some time. maybe this weekend.
Looks good, any issues?
No issues. Took my time so I ran out of daylight. I have to readjust the mount a little on the left side to be even with the right.
I’m not impressed with the sound so far. The factory unit sounded fuller. This one lacks lows and bass. But I haven’t messed that much with the eq. So I’ll do that after work today.
Discussion Starter #20
Deff check the Crossover points, I have mine set pretty low with the steepest cutoff 25hz I think, I'll check
Then look for MX or media Xpander, its Alpine's version of the old Loudness button
Setup\Sound\Advanced then the more arrows after TCR
1 - 20 of 91 Posts
