Hi all. Installed the alpine under seat subwoofer PWE-S8-WRA to the factory installed radio. The install went fine except the sound bar speakers are not working now. All the other speakers and the subwoofer are working fine. Has anyone else had this issue. Would appreciate any ideas you may have. Many thanks.
same issue
I have the same issue.
I will post again if i figure out what is going on.
Occasionally my speaker turns off then back on as well
I presume you tied into the rear speakers for your signal input, is that right? Are you sure you didn't sever the connections going up to the soundbar?
Reactions: DIRT BOY
Retired Moderator
Welcome to the Forum.
Reactions: nosweat10
Sorry for late response, but i just re ran the wiring harness through a better crevice/ channel and that resolved the issue. I assume the cables didn't like any pressure on them at all
