I am going to be installing a 2 row aluminum radiator in my 99' tj with the 4.0 and heard you can not run the regular green antifreeze as it will react wrong to the aluminum and that you have to run an orange color antifreeze that is designed for aluminum radiators?? I am just wondering if this is true before I install it
Thanks
Hrmm.. I had an all aluminum radiator in my Miata and I ran regular cheap green antifreeze/coolant and was fine. No weird reactions, always stayed cool, etc. Come to think of it, I put over 100k on the last Miata in 2 years after a radiator change and when I sold it I did a tune up (and radiator flush) and everything looked fine.
Thanks
You don't have to use orange antifreeze in an aluminum radiator. However, the orange has much longer-lasting corrosion inhibitors, and can last for up to 5 years, while the green usually needs to be changed after 2 years.
Don't mix the green and orange, by the way. That will greatly lower your coolant's protective capabilities. If you've been running green in your Jeep, and want to switch to orange, make sure you get your system thoroughly flushed. I'd check first, though, to make sure the switch won't harm other parts of your Jeep that use the coolant.
So if it's green just stay with it as it doesn't look old at all but will flush it anyways and just replace with what was in there..
Thanks again
Thanks
Green is fine, be sure to use distilled water. Change it at 36,000 miles, or every 3 years.
