1 - 9 of 9 Posts
Discussion Starter #8
Yes, this is Mopar part# for the clip in case somebody needs it,
they spend some time to find it.
It is located behind the front grille holding ambient temp sensor, its very fragile -easy to break while removing the sensor.
If it’s just the push clip that broke you can always just relocate the sensor up top where the earlier JK’s had them mounted. It snaps into the top mounting location without the need of a clip. I had to relocate my sensor up there due to a power steering cooler I mounted on the bottom rail.
1 - 9 of 9 Posts
