1 - 15 of 15 Posts
I've researched everything I can find, and just cannot bring myself to pull the trigger on my suspension upgrade. The guy at the 4x4 shop is likely getting tired of my indecision. I would very much appreciate any input you guys have on the suspension options. I'm hoping to finally decide this week.
Rig: '14 JK Unlimited Rubicon (JKUR) Manual transmission with 4:10 gearing. Stock except for bumpers (have Rock Hard front and rear with tire carrier), and a winch. This Jeep is not my daily commuter, but I do take it on trails and in the snow (I'm above the snowline). I'm not looking to be a hard-core rock crawler, but I live only 15 miles from the Rubicon Trail entrance, and I swear I can hear it calling me... So I do want to be able to run it, even if I take bypasses
Mods I've decided on:
- ARB 44 Differential covers
- Evap canister relocation
- oil/trans skid plate
- poison spyder rock brawler sliders (replace stock rubi sliders)
Suspension option I (4" w/ 35s)
- Teraflex Elite 4" LCG long arm kit 9550 shocks
- 1310 front driveshaft
- Goodyear Duratrac 34.8" tires
Suspension option II (6" w/ 37s)
- Teraflex Elite 6" LCG long arm kit 9550 shocks
- Rear HD adj trackbar
- 1310 front / 1350 rear driveshaft
- Toyo 37" MT tires
Down the road upgrades
- re-gearing
- chromalloy axles
Build Thread Queen
Thanks Starbrite. Reposted there
Honestly bud .. Less is better. For a 35 stay around 2.5-3" For a 37 3"-4"
Flat fenders and playing with bump stop height will give you plenty of up travel. Shock length/down.
Tire size .. Well only you can make that call. Stuck to a 35 if you don't plan on axle upgrades.
Gussets, sleeve/truss, rear shafts, etc
Are you dead set on long arms ?
Sticking w/ TF
https://www.quadratec.com/products/16190_2301.htm
Rock krawler has some nice kits too. Check out their long arm and 3 link kits.
Ken
I'll add here because I don't want to hijack his thread.
I noticed you "cared deeply" concerning flighty steering.
Back to lift height .. Unless running a aftermarket housing like a pro rock, TF or currie W/ added caster. Your steering/pinion angles up front are impossible to balance. Add a aftermarket DS (most likely need at that height) and Pinion angle takes precedents over caster = poor steering.
Here's a little more info on that
http://www.wranglerforum.com/f202/jeep-jk-caster-and-lifting-502001.html
^^^ What he said.
Less is more when it comes to lift unless you have the money to dump into maintaining the integrity of the jeep on a lift higher than 2.5" - 3" (the modification required really start to snowball).
Having a lower center of gravity is actually a good thing and if you really don't plan on being a hard core rock crawler than you most likely won't need that much lift.
Not sure if you got that height from goodyear or not but Id bet money if your looking at metric sized duratracs (315/70r17) you wont be anywhere near 35". Mine measured in at 33.5" on 17x9 wheels.
Oh, that's not good news... I just used a metric-standard converter I found on extremeterrain.com it said 34.4" snip attached
Most listed sizes are not true. That's still tech a 35" tire
tech based on what? Its size is its size regardless of what the calculator says. I would argue that since the tire ACTUALLY measures 33.5" its technically a 33" tire.
When I alter the PCM I put in 33.5 I dont put in the metric size or advertised size or 35", but its real size.
Im not sure where exactly calling a tire thats 33.5" tall a 35" tire is technically correct/accurate for anything.
IMDaveReynolds, for reference here is my 315 next to stock rubi before lift.
I believe he is saying that with the listed dimensions it's "technically" a 35" tire (and priced accordingly) but in actuality it measures closer to a 33" tire.
Arguing symantecs at this point......
Based on its metric label it may fall into the 35" tire category in a catalog but the very term "technically" refers to strict and accurate meaning....ie "
according to the facts or exact meaning of something; strictly."
which clearly shows that regardless of its label or position in a catalog, its not a 35" tire.
1 - 15 of 15 Posts
