1 - 16 of 16 Posts
Hey at least I warned you!
I have a 03 Rubi with 31's right now. Im trying to decide on a way I can get some larger tires on until I can afford a 4 or 4.5 in lift. Will a BB clear 33's if I don't disco? Note that I have the "tomb raider" edition, so I have different fender flairs. Thanks guys
Im just asking because I understand the Rubicons have stiffer springs so I figure they have a less chance to rub the flairs on a trail?
if anything.. 2'' bb and a 1'' bl
Retired Moderator
Just remove the BB. Here's a pic of my freshly installed OME lift with a 1.25" JKS body lift. Sitting on 33s. You'll have trouble wheeling 33s on a BB with nothing else. InfernoGirl has wheeled her's on 33s with a BB but she has trimmed her flares. (they are standard width flares though, so YMMV.)
Which OME lift did you go with? And their heavy or light springs?
Jeeper
:) That is one hot :firedevil: Barbie gold Jeep you got there Mr...... ;)
Meyers, my buddy JWM1986 had the heavy duty coils on his TJ and traded them out for softer coils. He only ran a soft top, and no winch so he didn't really need the extra duty, and they rode very stiff. I don't know that a hard top only is enough to warrant the extra, hard tops only weigh a bit over 100 lbs... not much more than a soft top and frame, or a lightweight passenger... ;)
OP, depending on your offroading usage, you can get by with 33's and a 2" bb. Trimming your flares will help, you'll still probably rub them if you disco. But if you tend to stay on road mostly, then you'll be ok. Before Mr. Unlimited comes in here and spanks me, I'll remind you that you simply must extend your bumpstops or all heck is likely to break loose..... :)
What does extend your bumperstops mean? I plan on taking it in to get whatever done. I dont have the tools or space and not to mention the patience to do it myself. I just want to get the BB with 33's until I can afford a better lift. I dont think I can trim my fender flairs though...
too bad.. a bb can be knocked out REALLY fast.. all you need is a air compressor, impact, spring compressors and a couple of sockets and a jack.. you'll end up paying a pretty penny to do something FAIRLY easy to do..
if your gonna offroad AT ALL.. you gotta do a 2'' bb and 1'' bl.. keep the bodylift if you ever do lift your jeep.. if you get a nicer lift kit later on you'll more than likely do a SYE.. then with the bl on you can do a tummy tuck
Here is a picture of an extended bump stop
Sorry its side ways . Its the piece on the right (thats actually the bottom front on the jeep
Discussion Starter · #16 ·
InfernoGirl said:
Trimming flares is easy...... Razor knife, chalk and half an hour is all you need, just mark 'em, score 'em with the knife, bend 'em in to break the plastic and peel em off..... ;)
Well I have the special edition flairs...I'm pretty sure they are untrimable
1 - 16 of 16 Posts
