I have an 03 sport w/ a 5 speed. If I depress the clutch for more than 4-5 seconds it will slowly start to engage the gear I'm in (@ a light waiting for green). It is next to impossible to get back to neutral once it starts and I eventually stall. There isn't an issue getting in and out of gears under normal driving. Any ideas what I'm dealing with?
Sounds like you've either got a slave cylinder or master cylinder leak. One of the two isn't holding pressure and is letting the clutch back out.
Until it is fixed I would just throw it into neutral at a red light and let the clutch out, then when the light turns green put it back in gear.
jrlane said:
BTW, you should be doing that anyway to prevent excessive use of the throwout bearing. :)
90% of the time, thats what I do. Guess I should just be a little more patient
