New to the forum - I have a new to me 2011 Sahara. I've bought a new front bumper that comes with pre-installed cube leds and full wiring harness with its own relay, fuse and switch.
I've seen plenty of threads about proper wiring to fog light switch or high beam and I'd like to get rid of the switch the kit came with and use a standard switch in the jeep.
The problem is I can't seem to find info on where or how I can tap into those switches. Can some please tell me where I can connect to?
Can't you just cut the factory plugs and butt splice them? Since they're led the most likely have a lower draw than the stock lights so the factory wiring should be fine.
