1 - 1 of 1 Posts
I went through the hood alignment questions and haven't found an answer. I recently picked up a TJ and the hood rubs the grill on the right side. It appears it has a new hood because the underneath has no stickers and the paint job on the underside is so poor you can see black through it. I measured every where I could think of and everything appears straight. One thing I did find was the measurement from the frame to the outside of the tub measured below the cowl is about 1 1/4 inch different from right to left. If it was even it I believe the hood would sit right. The jeep has Smittybilt step bars and it is visually obvious the tub is closer on one side than the other.
My questions is can the tub be adjusted and is it as simple as loosening the bolts and moving it? Thanks in advance for any input.
1 - 1 of 1 Posts
