Wow...my mind is blown after doing some searching around for a lift. I was debating on either going with the Pro-Comp 4" kit...until I read the last thread...or 4WD's 3" TJ lift. I am looking to run 33" tires..pavement and some trail...nothing extreme..yet. I have been told that the 4WD kit is pretty good. I was also told to get the adjustable track bar and that the driveline should be fine. The kit includes the following:
4 coil springs, 4 shots with boots, front sway bar disconnects and rear sway links, rear track bar relocation bracket, bump stop extensions, and a transfer lowering kit.
What do you guys think? Anything else out there better for me? Any suggestions would be awesome. Really do not want to spend the money right now on a driveshaft and SYE.
THANKS~!
THANKS~!
