Ok I searched and never really found what im looking for. I have a stock 07 with 265 75 r16 tires. I want to go with a 3" lift with 33's what size rim and back space would you run. any help would be great
Be easier if you narrow it down alittle. You could run wheels that are 16'' tall on up to 20'' or more and 7'' wide up to 10''. If your concerned about rubbing it depends on the tire size you would like to run, then worry about what backspacing you need to make that work.. If your planning to keep using your current tires then you don't have to worry about backspacing really. Most aftermarket wheels will have less backspacing then the stock wheels which will push the wheel further outside of wheel well. Just find wheels you like is say 16'' x 7'' or 8'' width..
With a 3inch lift you'll want 35-37 inch tires, 33's will look silly. I'd do just a simple budget boost if you want to run 33's.
