1 - 1 of 1 Posts
After trying to figure out what was wrong with my 97 TJ I have finally found it.
Problem: I had what I thought were severe problems. My cluster would flatline until I "beat the snot out of it" and my dash would go dark when using my lights. Hit a bump and they would randomly go out.
Answer: Took my dash apart, removed cluster then took the female ends of the dash harness off the steel bracket. Cut the bracket off and plugged the harness back in and reassembled. I haven't had a single problem going on two weeks.:dance: I believe the problem was a unsecure connection caused by a foolish design. They should have gone with a locking plug like every other connection in the ENTIRE jeep.
1 - 1 of 1 Posts
