Everything seems to be ok when I look at it when the car is stopped. Wondering if anyone had the same issue and identified it. I have a 2 door 2012 w/ a TF leveling kit.
Heat shield above muffler most likely.
I was looking at again last night and I think it is the heat shield. What did you do to fix yours?
I just folded a corner that was touching muffler, rattle gone :). I think it's slightly off bottom panel, I remember being able to push the heat shield and it stayed in place
Let me know if it works
Thanks it worked. The muffler has a lot of give though. I can move it quite a bit by hand. But I guess that's just how the car is designed with the rubber grommits holding it in place.
