1 - 12 of 12 Posts
I'm at max capacity on those two holes by the rear view mirrors on either size. I need to get some additional wires through to the cabin, any other easy to access holes I can route some cables through? If I'm outta options, is it safe to drill a new hole? How do people combat this problem?
2017 jku here if that helps
Sent from my SM-G970U using Tapatalk
Have you used the hole in firewall on drivers side. It seems like theres a hole there that I ran spod wire through
There is a hole behind the battery. Pull the insulation forward to access it. Comes through behind the glove box.
2016 Wrangler JKU sport.
I did this to get my 8 gauge wire to battery from my subwoofer amp. You can actually do this and use silicone to seal the wire into the hole. Took me about 5 mins to get the wire through and close it up.
Thanks, I'll search for this one. I always heard of this legendary hole but wasn't bold enough at the time to search for it.
Feed the wire down on an angle. be aware that it might go behind the carpet.
Just below the brake booster there is a soft membrane (likely where the clutch rod goes through for the manual) it’s a large enough hole to put a plug through.
I used that hole for the control wires for my aux braking system I use when towing the Jeep.Just poke a hole in the membrane.
You can also just drill a new hole, just be careful. I had to drill a new hole for a cable to attach to my brake pedal when I changed brake system. No big deal, even for a klutz like me.
1 - 12 of 12 Posts
