Just wondering if anybody knows how to install a PCM on 06 jeep wrangler it doesn't look that difficult from looking at it
From my '05 FSM
REMOVAL
USE THE DRB SCAN TOOL TO REPROGRAM
THE NEW POWERTRAIN CONTROL MODULE
(PCM) WITH THE VEHICLES ORIGINAL IDENTIFICATION
NUMBER (VIN) AND THE VEHICLES
ORIGINAL MILEAGE. IF THIS STEP IS
NOT DONE, A DIAGNOSTIC TROUBLE CODE
(DTC) MAY BE SET.
To avoid possible voltage spike damage to the
PCM, ignition key must be off, and negative battery
cable must be disconnected before unplugging PCM
connectors.
(1) Disconnect negative battery cable at battery.
(2) Remove plastic shields from over four electrical
connectors. Shields snap to connectors.
(3) Carefully unplug four electrical connectors (3)
(Fig. 5) or (Fig. 6) from PCM.
(4) Remove three PCM mounting bolts (1) or (2)
and remove PCM from vehicle.
INSTALLATION
(DTC) MAY BE SET.
(1) Install PCM and three mounting screws to
vehicle.
(2) Tighten screws to 4 N·m (35 in. lbs.).
(3) Check pin connectors in PCM and four electrical
connectors for corrosion or damage. Also check
pin heights in connectors. Pin heights should all be
the same. Repair as necessary before installing electrical
connectors.
(4) Install four electrical connectors (3) (Fig. 7) or
(Fig. 8) to PCM.
(5) Install plastic shield to electrical connectors.
(6) Install battery cable.
(7) Use a scan tool to reprogram new PCM with
vehicles original Vehicle Identification Number (VIN)
and original vehicle mileage.
Knows a couple things...
It won't take that long for the PCM's adaptive memory to learn the new parameters. I'd say within a couple hours max if you are taking short trips during those first hours. It might run a little odd or rough until it gets back in sync.
Ok I was wondering I have only gone about 100 miles on it and it shifted hard a couple times was worried lol
But very short trips of course I only drive like 2 miles to work lol, was I susposed to flash it too like turning the key in the ignition and turn on the lights n stuff
