here it is and just a note toe is measured on here as inches not degrees. He said it was 9 but when he tightened every thing down it changed to 8 but that was still goodCan you post your alignment results sheet?
This is a important step ^^Stupid question. Did the shop loosen all the control arms and retighten? When I installed new springs on mine, I skipped that step. There was a noticeable increase in the pull to right. Once I went back and loosened the control arms and retightened, it was much closer to stock.
I know my shop didn't do this step when they installed the leveling kit yesterday. I don't notice a pull, but I may have them do this just in case.Stupid question. Did the shop loosen all the control arms and retighten? When I installed new springs on mine, I skipped that step. There was a noticeable increase in the pull to right. Once I went back and loosened the control arms and retightened, it was much closer to stock.
:thumb:Mine pulled to the right slightly after lift but corrected with caster adjustment to 5*
i don't know. I wasn't there when they did the work. But hooefully they did that. This is all they do us lifts and such so I would like to think they did.Stupid question. Did the shop loosen all the control arms and retighten? When I installed new springs on mine, I skipped that step. There was a noticeable increase in the pull to right. Once I went back and loosened the control arms and retightened, it was much closer to stock.
so should I do this just to make sure.if so how loose should I go and what torque to re tighten to. And here is a stupid question but I'm not a car mechanic so here goes. I see pictures of rancho control arm brackets and the control arms are upper and lower. Are these the ones? And I am going to get bracjets to correct caster but not just yetThis is a important step ^^
It's pretty easy. Just loosen enough that arm moves freely. You don't have to remove. Upper control arms are 18mm and lower arms are 21mm. You'll need a box wrench and socket. Upper control arms are re-torqued to 75 ft-lbs and lower are 125 ft-lbs.so should I do this just to make sure.if so how loose should I go and what torque to re tighten to. And here is a stupid question but I'm not a car mechanic so here goes. I see pictures of rancho control arm brackets and the control arms are upper and lower. Are these the ones? And I am going to get bracjets to correct caster but not just yet
