1 - 19 of 19 Posts
Pucker factor X10.
Reactions: Legobusier
Wow!
wow just wow. so lucky to be alive. one of those things that could have been so bad.
That is not a standard YJ drive shaft. Is as a slip shat and not a slip yoke and the size of the yoke we see is way bigger that standard and the tube is also bigger and longer than what could be a front or rear shaft.
Other go to the point just before me.
I simply answer to the tread name.
But if you want I can say it too, wow, happy that no body got hurt.
But to me, the point is that this happen when maintenance of mods are not properly done on a vehicule. People can get enjured! But this time no one was.
Witch is a good thing.
Discussion Starter · #11 ·
Witch is not a good thing
OP: That's crazy this is even possible, glad there were no injuries. It fell off of a vehicle that was driving?
I don't know...I assume so...
that's about as freakish as they come. back in the seventies, i seen the aftermath of an el camino catapulting after the front drive shave exploded. The el camino ended up in a ford dealership taking out about 6 new cars.
that Range Rover is probably totaled
WOW. It was his lucky day. That would have scared the bejesus out of me.
That's insane and could have been worse.
I wonder if it was just a score from a metal scrapper taking it to the local recycled metal-mart and it fell off his truck bed or if it actually broke off a vehicle while driving, if it did, I assume that would damage the vehicle it came off of?
Discussion Starter · #16 ·
Yeah, I bet the RR driver experienced a serious slipped shat.
L'impression que c'est facile de rire d'un erreur d'écriture quand le sujet est la sécurité. ;)
Mistake happen when you contribute to a forum that is not writen in you primery language. Don't you think.
Back to topic guys!
1 - 19 of 19 Posts
