1 - 20 of 21 Posts
I am looking to replace wheels and tires to go with my 2.5" lift. Wondering if anyone has not installed the TPMS sensors and disabled the system with a programmer? Not really 100% sure there is one for 2013 JKU but looking for options.
Yep. I didn't have the sensors installed when I got new wheels and tires and disabled the thing via flashcal. My jeep doesn't have the EVIC to show me the pressures- it's just the idiot light. Knowing the pressures at a glance would be useful but just having the light would be an annoyance.
I didn鈥檛 buy the sensors when I went with new wheels and tires on my 2014. I disabled the system with the AEV procal. Having the tire pressures displayed was nice but I didn鈥檛 think the cost of new sensors was worth it. Straight old school pressure gauge now.
EVIC is great I wouldn't get read of it.
Sensors can be transferred from old wheels to the new ones.
Basic tpms IDK 50/50
if someone else drives your jeep I would consider keeping it.
I wont loan my jeep out, but if you have no clue how to check tire pressure, you should not be driving.
Got rid of the sensors almost as soon as I got the Jeep. Went to 37's with beadlocks and don't care for the notification/chimes/warnings everytime I air down. If my tire goes flat, I don't need the readout on the dash to tell me...
I have an '07 so I don't have to be bothered by it. I did have to grumble at my local tire shop when I had to get new rubber and they installed TPMS valves and wanted to charge me for it.
The biggest advantage of tpms, or at list how I see it, is that it would alert you of pressure drop in advance while vehicle is in motion so that you can safely leave the road and fix/replace the tire. Also it would also probably save your tire, driving on flat even a short distance will damage it beyond repair.
Yes its a part of "idiot" package but imo useful one.
Agreed. The jeep is the first vehicle I have owned with TPMS so it is not needed but nice to have. Last week, I got a small pebble in the bead in the rear passenger wheel. I don't usually see that tire as it is on the "other side" and the TPMS alerted me of the issue. Was loosing about 1psi per day. Because the TPMS showed the actual pressure, I was able to monitor the situation and air up as needed until I could fix the issue. The chiming is annoying when aired down for wheeling though.
Mine's been turned off for several years.
Disabled with Flashpac
There are a couple frequencies that the sensors can be. They changed mid 2013. I bought a couple craigslist wheels right before I got my offroad tires. They were from an early 13 Wrangler and mine is a 14. They don't register when on the Jeep. Doesn't matter to me because I'm aired down when I run these tires. No, I don't disable anything. When I put the OEM wheels/tires back on (like now, because my next offroad date is 3 weeks away), the low pressure warning goes away.
I transferred mine over.. wasnt a big deal for the tire shop.. why wouldnt you want them, the more info the better..
1 - 20 of 21 Posts
