I have a 2011 3.8l Wrangler with 73k miles. Today while inspecting for routes to wire some lights I noticed a couple wet spots and wonder if I should be concerned. What do you think? One is the thermostat housing. The wet line on it isn't as clear in the picture as it is in person. The other is at the bottom pulley. Not sure what this could be.
Looks like a slow coolant seep. I would either keep and eye on it or fix it personally.
I did some research and plan to fix the thermostat leak soon. What I'm not sure about is the wet spot at the bottom. What could it be from?
Water pump? There's some sort of rubber O-ring in there which apparently lets go after awhile. I think @Wrangleur has posted a picture or two in other threads pointing it out (not sure if @ works here...)
