Is there a particular brand of ATF-4 I should use for my Power Steering? I can't really believe there is that much difference, especially for a Power Steering pump. I could believe that the transmissions are more sensitive.
Ian
There are a number of "ATF+4"*brands that you can use. If you're more comfortable using Mopar ATF+4 there are a number of on-line vendors where you can get it, including the dealer.
I just use whatever I can find at Oreillys. It's all the same. It's just hydraulic fluid.
I buy the higher quality stuff since it is also used in the NP241 on my vehicles. That way I have only a couple of fluids I need to have on hand. Not sure what T-case a Sahara has and what fluid it takes.
