do they have a website?Mine is sprayed with Super liner, a product sold in Austin TX.
It holds up well against everything except sliding on rocks, but not much does.
Go on this link Jeep Wrangler TJ and TJ Unlimited (LJ) Tube Fenders & Body Armor and just choose one of the first four selections which are fenders which comes with all the hardware and then pick one of the next six selections for flares based on if you got arched or overline if you want to add a flares. Fenders run $599-$799 and flares go from $139-$249iv been looking at the metal cloak fenders and there website doesn't make much sense to me what all do you need to buy and how much did it cost? it shows the flares separately?
Bedliner.comdo they have a website?
I wonder if you can buy it and have a body shop do it for you or someone who does truck bedsROK1 said:Bedliner.com
Thanks!!Bedliner.com
It's just the normal decals, I clear coated them into my hood.Yeah, I really like the bed lined finish. What did you do for the Rubicon label. Is it sprayed with bed liner or paint? Ordinary spray paint seems to take to mine very well.
Thanks - had the rack made by a small marine outfitter in AustinYour jeep is amazing man! Its the same set up im going for but with a green jeep. Well done! Where did you get your rack from?
It's the nature of the product. Superliner from Bedliner.comHow did you guys get the Bed liners to look smoother then most Bed liners? All the ones I have seen look really rough but y'all's looks ALOT better.
Same springs I'm putting on my jeep when I get my winch. My 3" savvys aren't gonna cut it for what I'm going for.I recently added Metalcloak 3.5" springs
http://www.wranglerforum.com/f5/metalcloak-3-5-lift-first-impressions-236170.html#post3653358
AND
replaced my steel Metalcloak arched fenders for aluminum.
http://www.wranglerforum.com/f5/aluminum-metalcloak-fenders-nice-236158.html
Have any pictures of how it sits at ride height? My plan was to go with their 3.5" springs up front and RC's 2.5" springs in the rear since they're like a slinky and to help level out the jeep like what Imped had done. But if those metalcloaks front and rear sit level then I'll go with those. Also if you do have a shot of it at ride height what is your tire size. Thanks in advance man.I recently added Metalcloak 3.5" springs
I don't know if it was his main reason but he had a taller spring in the front than in the rear to help level it out and to take away from the factory take some. Went with the RC's because of their unsprung length.I am not sure what Imped did with RC 2.5 springs, but I am sitting an inch and a half higher on the MC springs than I was on 933 OME springs with an additional .75 spacer, but I also took 40lbs off the front by swapping fenders.
