Hey Wrangler Forum!
First post here!
Attempting to install my own Audio system in the JK and have a few questions regarding installation process...
As of now, I plan on setting up a amp + sub in my 2016 JKU, then in the next month I will add a second amp for the component speakers. I plan on wiring everything up where it's a easy enough to just plug in the amp and re-route all the component speakers.
I really want to place the amps under the driver & passenger seats, but can't seem to find any info about seat brackets. Read somewhere that a user unbolted the 6 bolts that are attached to the rails instead of using unbolting the 4 big-boy bolts and possibly getting a hernia :atomic:.
User stated it was way easier, but I haven't read or seen anyone else talk about it...
Ideally, I would like to keep the 4 bolts untouched so I don't have to bust out the breaker bar
ullinghair:
Another question I have is for the component speakers. Does anyone know if all stock component speaker wires run along the driver or passenger side? Or both? Can't seem to find this info either. I plan on wiring the power wire on the driver side and don't want it to interfere with the component speakers.
I created a diagram (attached) to help my build, if someone can give me the greenlight that would be great. I don't have anyone to help me out, so I'm trying my best to get it right the first shot.
Looking for a ground location as well, since the amp will be under the seat, I would like to stray away from drilling a hole into the frame if I don't need to, although I will sand whatever surface regardless.
Apologies if I posted in the wrong section!
First post here!
